Abby_Collins14
Building add-in: User input for each column
Hi! I am working on building a JMP script/add-in that automatically does TOSTs for a user selected number of columns. I have the scripting working to prompt the user to select the columns using the code below. However after that, I would like to have a window pop up that would allow the user to input the practical equivalence (or have an option to use a multiplier of the SD) for each selected column. Does anyone know how to do this or have good reference of where I could learn?
Thanks!
Code for user input column picker:
dt = Current Data Table();
cnames = dt << Get Column Names(string);
n2 = N Items(cnames);
lstNumCol = dt << get column names(numeric);
New Window("Select Parametrs for Equivalence Testing",
	<<modal,
	clb = Col List Box(<<set items(lstNumCol))
lstColNames = clb << get selected;
Show(lstColNames);
n = Length(lstColNames);
Re: Building add-in: User input for each column
There are many options, here is one using Table Box
nw = New Window("Select Parametrs for Equivalence Testing",
	<<modal, << return result,
lstColNames = nw["clb"];
	<<modal,
	Table Box(
		String Col Box("column", lstColNames),
		Number Col Edit Box("practical equivalence ", Repeat([.], N Items(lstColNames)))
Other good option could be Lineup Box and using Number Edit Boxes. You could also update your initial window dynamically based on user selections, but I would start with something simpler like having two modal windows.
I would also suggest you add Button Box("OK") and Button Box("Cancel") if you are using modal windows. JMP will automatically add "OK" button but if you add it yourself, you can trigger actions when user presses that and generally it nice to provide user an option to cancel (remember to check which button user did press).
You can add Radio Box for user to select value from and then build your display boxes based on that selection. There are then plenty of different ways on how you wish to utilize the selection user has made, this is one of the simpler ones: just change the title of number col edit box
OPTIONS = {"practical equivalence", "sigma multiplier"};
	clb = Col List Box(<<set items(lstNumCol)),
	rb = Radio Box(OPTIONS)
user_selection = nw["rb"];
	<<modal,
	Table Box(
		Number Col Edit Box(OPTIONS[user_selection], Repeat([.], N Items(lstColNames)))
Scripting Index does contain some good material about the display boxes, for example here Scripting Guide > Display Trees > Construct Custom Windows > Construct Display Boxes for New Windows
6 REPLIES 6
	<<modal,
	Table Box(
Abby_Collins14
amazing, thank you!!
My main goal is to have a window pop up first that asks the user if they would like to enter a practical equivalence or use a multiplier of the standard deviation, and if they pick a multiplier of the SD they can then input "3" or whatever value. Is this possible?
Thank you so much for your help!
Abby
	<<modal,
	Table Box(
Abby_Collins14
Thank you so much this is very helpful!
Abby_Collins14
if they pick "sigma multiplier" can that prompt a different window that would be just one box for all parameters? i.e. the sigma multiplier would be the same for all columns so they only need to enter it once.
Thanks for the help!!
Sure, you can for example use If statement to check what the user did select and then create the window accordingly.
