js1985
Best way to create a control chart dashboard
Hello everyone,
I have to manage several control charts, each of them is made by a datatable with a script to be run to create the control charts, currently the control chart itself it's not saved after review, just the datatable.
I'm looking for a simple solution to create a sort of dashboard where I can review all charts together, ideally it should be a script picking up the data from all datatable anche generating the charts automatically.
Is there a way to do that?
Thanks.
P_Bartell
Level VIII
Re: Best way to create a control chart dashboard
You may want to check out the Dashboard Builder capability in JMP. Here's a link to the JMP online documentation for Dashboard Builder:
https://www.jmp.com/support/help/en/15.1/#page/jmp/create-dashboards-2.shtml#
And you may want to package the whole body of work into a JMP Project as well?
https://www.jmp.com/support/help/en/15.1/#page/jmp/jmp-projects.shtml
The simple way is to open all the charts at once, then select Window > Combine Windows... on Macintosh. There is a similar method for Windows version. You name the dashboard, select the windows (e.g. charts) you want, and click OK. Then click the red triangle to select Save Script. Now you just have to run the script in the future to get the same dashboard with fresh data.
