Beginner JSL query
I want to save selected rows from a table in a jmp file and also the inversion of the selected rows in another jmp file after using the partition function. I went through some examples and other threads but I am not able to save the selected rows and the inverted rows. I must be doing something wrong. Does anyone have any idea how it can be done in JSL?
dt = Open( "C:/Users/Desktop/driver/MASTER.jmp" );
f = Function({a}, theRows = Current Data Table() << get selected rows;
Show(theRows);
obj = Partition(
       Y( :Failed ),
       X(
             :VOLUME,
             :FAMILY,
             :CONFIG
       Method( "Decision Tree" ),
       Validation Portion( .2 )
obj << ShowGraph( 0 );
obj << SplitBest( 4 );
obj << on close( Clear Symbols( rs ) );
action = 0;
actionsubset = 0;
look_window = New Window( "Decision",
       Lineup Box( N Col( 1 ),
             V List Box(
                    Text Box( "After selection of the rows,go for Plot?" ),
                    H List Box(
                          spacer box(size(100,5)),
                          Button Box( "Continue",
                                 action = 1;
                                 look_window << close window;
                                 //obj << Save( "C:\Users\Desktop\test.csv" );
                                 //filepath = "C:\Users\Desktop\driver";
                                 //rs << save( filepath || "\" || "p1.jmp" );
                                 Include("C:/Users/Desktop/driver/plot.jsl");
                          Button Box( "Close",
                                 action = 2;
                                 Close( obj, nosave );
                                 //Throw( "You cancelled the script." );
Re: Beginner JSL query
The first item I can see, is that you are setting the variable "obj" to be a pointer to the output report for the Partition platform, and then in the New Window, you are using "obj" as if it is a pointer to your data table.  The pointer to your data table is the variable "dt" created when you opened the table.
Below is a simple example that shows a simple way to create a data table from selected rows, and then to create another data table from the inverse of that selection
dt << select where( :sex == "F" );
dtF = dt << subset( selected rows( 1 ), selected columns( 0 ) );
dt << invert row selection;
dtM = dt << subset( selected rows( 1 ), selected columns( 0 ) );
close( dt, nosave );
