switzal87
Bar Graph and Line Graph overlay
How can I create same graph on JMP?
and I have the following raw data:
I hope somebody could help me out!
Thanks in advance!
robot
Re: Bar Graph and Line Graph overlay
I take what I said back about both bars and lines in the same window.  Below should give you the graph for which you are looking.
// Create original data table.
dt = New Table( "Defects",
      Add Rows( 14 ),
      New Column( "Defects", Numeric, Continuous, Format( "Best", 12 ), Set Values( [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14] ) ),
      New Column( "A", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( Random Uniform( 0, 0.002 ) ) ),
      New Column( "B", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( Random Uniform( 0, 0.002 ) ) ),
      New Column( "C", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( Random Uniform( 0, 0.002 ) ) ),
      New Column( "D", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( Random Uniform( 0, 0.002 ) ) ),
      New Column( "E", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( Random Uniform( 0, 0.002 ) ) )
// Transpose data table.
dtTrans = dt << Transpose( columns( :A, :B, :C, :D, :E ), Label( :Defects ), Output Table( "Transpose of Defects" ) );
// Add yield columns.
dtTrans << New Column( "Yield1",
      Numeric,
      Continuous,
      Formula(
            1 - Sum(
                  :Name( "1" ),
                  :Name( "2" ),
                  :Name( "3" ),
                  :Name( "4" ),
                  :Name( "5" ),
                  :Name( "6" ),
                  :Name( "7" ),
                  :Name( "8" ),
                  :Name( "9" ),
                  :Name( "10" ),
                  :Name( "11" ),
                  :Name( "12" ),
                  :Name( "13" ),
                  :Name( "14" )
dtTrans << New Column( "Yield2",
      Numeric,
      Continuous,
      Formula(
            1 - 2 * Sum(
                  :Name( "1" ),
                  :Name( "2" ),
                  :Name( "3" ),
                  :Name( "4" ),
                  :Name( "5" ),
                  :Name( "6" ),
                  :Name( "7" ),
                  :Name( "8" ),
                  :Name( "9" ),
                  :Name( "10" ),
                  :Name( "11" ),
                  :Name( "12" ),
                  :Name( "13" ),
                  :Name( "14" )
// Create graph.
dtTrans << Graph Builder(
      Variables(
            X( :Label ),
            Y( :Yield1, Side( "Right" ) ),
            Y( :Yield2, Position( 1 ), Side( "Right" ) ),
            Y( :Name( "1" ), Position( 1 ) ),
            Y( :Name( "2" ), Position( 1 ) ),
            Y( :Name( "3" ), Position( 1 ) ),
            Y( :Name( "4" ), Position( 1 ) ),
            Y( :Name( "5" ), Position( 1 ) ),
            Y( :Name( "6" ), Position( 1 ) ),
            Y( :Name( "7" ), Position( 1 ) ),
            Y( :Name( "8" ), Position( 1 ) ),
            Y( :Name( "9" ), Position( 1 ) ),
            Y( :Name( "10" ), Position( 1 ) ),
            Y( :Name( "11" ), Position( 1 ) ),
            Y( :Name( "12" ), Position( 1 ) ),
            Y( :Name( "13" ), Position( 1 ) ),
            Y( :Name( "14" ), Position( 1 ) )
      Elements(
            Bar(
                  X,
                  Y( 3 ),
                  Y( 4 ),
                  Y( 5 ),
                  Y( 6 ),
                  Y( 7 ),
                  Y( 8 ),
                  Y( 9 ),
                  Y( 10 ),
                  Y( 11 ),
                  Y( 12 ),
                  Y( 13 ),
                  Y( 14 ),
                  Y( 15 ),
                  Y( 16 ),
                  Legend( 3 ),
                  Bar Style( "Stacked" ),
                  Summary Statistic( "Mean" )
            Line( X, Y( 1 ), Y( 2 ), Legend( 4 ), Row order( 0 ), Summary Statistic( "Mean" ) )
            Dispatch( {}, "1", ScaleBox, {Format( "Percent", 12, 2 )} ),
            Dispatch( {}, "Yield1", ScaleBox, {Format( "Percent", 12, 2 )} ),
            Dispatch( {}, "400", ScaleBox, {Legend Model( 4, Properties( 0, {Line Width( 3 )} ), Properties( 1, {Line Width( 3 )} ) )} ),
            Dispatch( {}, "graph title", TextEditBox, {Set Text( "Sample Trend" )} ),
            Dispatch( {}, "Y title", TextEditBox, {Set Text( "Defect Rate" )} ),
            Dispatch( {}, "Y r title", TextEditBox, {Set Text( "Yield" )} )
robot
Hi Switzal87
In JMP, all columns must be of the same data type, so it is not possible to have both defect and yield data in the same column.  So the first thing you must do is transpose your defect data.  Once you have a transpose of the defect data, you can add calculated columns for yield, and then create something similar to your example using Graph Builder.  It may be possible to create something with both bars and lines in the same window, but I am not certain how to do this.  The example below should get you close.
      Add Rows( 14 ),
            Numeric,
            Continuous,
      New Column( "E", Numeric, Continuous, Format( "Percent", 12, 2 ), Formula( Random Uniform( 0, 0.002 ) ) ),
// Create graph.
      Numeric,
      Continuous,
      Formula(
            1 - Sum(
                  :Name( "1" ),
                  :Name( "2" ),
                  :Name( "3" ),
                  :Name( "4" ),
                  :Name( "5" ),
                  :Name( "6" ),
                  :Name( "7" ),
                  :Name( "8" ),
                  :Name( "9" ),
                  :Name( "10" ),
                  :Name( "11" ),
                  :Name( "12" ),
                  :Name( "13" ),
                  :Name( "14" )
      Numeric,
      Continuous,
      Formula(
            1 - 2 * Sum(
                  :Name( "1" ),
                  :Name( "2" ),
                  :Name( "3" ),
                  :Name( "4" ),
                  :Name( "5" ),
                  :Name( "6" ),
                  :Name( "7" ),
                  :Name( "8" ),
                  :Name( "9" ),
                  :Name( "10" ),
                  :Name( "11" ),
                  :Name( "12" ),
                  :Name( "13" ),
                  :Name( "14" )
      Variables(
            X( :Label ),
            Y( :Yield1 ),
            Y( :Yield2, Position( 1 ) ),
            Y( :Name( "1" ) ),
            Y( :Name( "2" ), Position( 2 ) ),
            Y( :Name( "3" ), Position( 2 ) ),
            Y( :Name( "4" ), Position( 2 ) ),
            Y( :Name( "5" ), Position( 2 ) ),
            Y( :Name( "6" ), Position( 2 ) ),
            Y( :Name( "7" ), Position( 2 ) ),
            Y( :Name( "8" ), Position( 2 ) ),
            Y( :Name( "9" ), Position( 2 ) ),
            Y( :Name( "10" ), Position( 2 ) ),
            Y( :Name( "11" ), Position( 2 ) ),
            Y( :Name( "12" ), Position( 2 ) ),
            Y( :Name( "13" ), Position( 2 ) ),
            Y( :Name( "14" ), Position( 2 ) )
      Elements(
            Position( 1, 1 ),
            Line(
                  X,
                  Y( 1 ),
                  Y( 2 ),
                  Legend( 12 ),
                  Row order( 0 ),
      Elements(
            Position( 1, 2 ),
            Bar(
                  X,
                  Y( 1 ),
                  Y( 2 ),
                  Y( 3 ),
                  Y( 4 ),
                  Y( 5 ),
                  Y( 6 ),
                  Y( 7 ),
                  Y( 8 ),
                  Y( 9 ),
                  Y( 10 ),
                  Y( 11 ),
                  Y( 12 ),
                  Y( 13 ),
                  Y( 14 ),
                  Legend( 10 ),
                  Summary Statistic( "Sum" )
            Dispatch(
                  "400",
                  ScaleBox,
                  {Legend Model(
                        12,
            Dispatch( {}, "Y title", TextEditBox, {Set Text( "Yield" )} ),
            Dispatch( {}, "Y 1 title", TextEditBox, {Set Text( "Defect Rate" )} )
switzal87
Cool! not the exact output that I want but still closer!
When I run the code I have the following graph:
Thanks a lot robot​!
Is there a continuing issue?  When I run Robot's code I get the following graph, which is exactly in the style you shown.
The graph you displayed has a Y Grouping that is splitting the bar charts and the line charts, not letting them overlay.
robot
      Add Rows( 14 ),
      Numeric,
      Continuous,
      Formula(
            1 - Sum(
                  :Name( "1" ),
                  :Name( "2" ),
                  :Name( "3" ),
                  :Name( "4" ),
                  :Name( "5" ),
                  :Name( "6" ),
                  :Name( "7" ),
                  :Name( "8" ),
                  :Name( "9" ),
                  :Name( "10" ),
                  :Name( "11" ),
                  :Name( "12" ),
                  :Name( "13" ),
                  :Name( "14" )
      Numeric,
      Continuous,
      Formula(
            1 - 2 * Sum(
                  :Name( "1" ),
                  :Name( "2" ),
                  :Name( "3" ),
                  :Name( "4" ),
                  :Name( "5" ),
                  :Name( "6" ),
                  :Name( "7" ),
                  :Name( "8" ),
                  :Name( "9" ),
                  :Name( "10" ),
                  :Name( "11" ),
                  :Name( "12" ),
                  :Name( "13" ),
                  :Name( "14" )
// Create graph.
      Variables(
            X( :Label ),
      Elements(
            Bar(
                  X,
                  Y( 3 ),
                  Y( 4 ),
                  Y( 5 ),
                  Y( 6 ),
                  Y( 7 ),
                  Y( 8 ),
                  Y( 9 ),
                  Y( 10 ),
                  Y( 11 ),
                  Y( 12 ),
                  Y( 13 ),
                  Y( 14 ),
                  Y( 15 ),
                  Y( 16 ),
                  Legend( 3 ),
switzal87
thanks for the great help!
