RMSEBird223
Automatically change factor settings of a profiler object using a for loop
Hi all,
I would like to automatically change the factor settings of a profiler object. If I address each factor directly it works as expected:
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
obj = dt << Profiler(
	Y(
		:Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula ELONG,
		:Pred Formula HARDNESS
	Desirability Functions( 1 )
//works
obj << Term Value("SILICA"(5, Min( -10 ), Max( 6 ), Lock( 1 ), Show( 1 ) ));
However, if I want to loop over all factors to change the respective settings, nothing happens.
	Y(
//does not work
FactorList = {"SILICA", "SILANE"};
for(i=1, i<=n items(FactorList), i++,
	Eval(
		Eval Expr(
			obj << Term Value(
				Expr(FactorList[i])( 5, Min( -10 ), Max( 6 ), Lock( 1 ), Show( 1 ) )
Using Eval(Eval Expr()) usually solved it when I had similar issues. Sadly, this isn't helping this time.
Thanks for your help!
Re: Automatically change factor settings of a profiler object using a for loop
Using this method appears to work
	Y(
//does not work
	Eval(
		Parse(
			"obj << Term Value(
				\!""||FactorList[i]|| "\!"( 5, Min( -10 ), Max( 6 ), Lock( 1 ), Show( 1 ) )
To debug your script, you can check what the EvalExpr() part does return
i = 1;
term_expr = Eval Expr(obj << Term Value(Expr(FactorList[i])(5, Min(-10), Max(6), Lock(1), Show(1))));
show(term_expr);
it is something like this which is incorrect syntax
term_expr = obj << Term Value("SILICA" << {5, Min(-10), Max(6), Lock(1), Show(1)});
And here is one way of dealing this
dt = Open("$SAMPLE_DATA/Tiretread.jmp");
	Y(:Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula ELONG, :Pred Formula HARDNESS),
	Desirability Functions(1)
terms = {"SILICA", "SILANE"};
For Each({term}, terms,
	Eval(Substitute(
		Expr(obj << Term Value(_term_(5, Min(-10), Max(6), Lock(1), Show(1)))),
		Expr(_term_), Name Expr(AsColumn(dt, term));
	Y(
//does not work
	Eval(
		Parse(
			"obj << Term Value(
i = 1;
show(term_expr);
	Eval(Substitute(
