Brad_Park
Automatic local data filter
Hello, everyone,
Could you please give me your hand to solve problems.
1. The situation
I am trying to make a script to automate drawing graphs every day.
This is a situation that I need to create data for each equipment station daily used.
Meanwhile, as the number of stations is large (ex. there's 40 stations), I cannot plot all of station in one graph. So I select three stations on one graph with local data filter.
However, as the used equipment station changes every day,
I cannot use code like below,
Local Data Filter(
Width( 178 ),
Add Filter(
columns( :Station ),
Where( :Station == {"Tx #5", "Tx #6", "Tx #7"} ),
Display( :Station, Size( 172, 493 ), Height( 493))
2. Designed Solution
So I came up with the following method.
  1. select the Station column.
  2. Make the column as a list
  3. Remove duplicate values ​​from the list. (->To get a list of used stations)
  4. Use the local data filter to select 3 stations from the list obtained in step 3.
3. Problem
  1. Station column is selected and I made it into a list, but duplicates are not removed.
  2. I have no idea how to apply the local data filter for each 3 stations in the list.
Thank you.
-Sejin Park.
Re: Automatic local data filter
I am not quite sure what your question is, but let me make a guess.  You want to get either, all of the values from a column into a list, or you want to get all of the unique values from a column into a list.  Below there are 2 examples, one that will read all values into a list, and the second example will get only the unique values.
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
// Get all values from a column
allValueList = dt:sex << get values;
// get unique values
summarize( dt, uniqueValueList = by(:sex));
// Look in the log for the output
Show("All Values", allValueList, "Unique Values", uniqueValueList);
You need to use the Summarize() function. If you specify your column as the By() column, it will return a list of unique values for Stations
summarize( stationList = By( :Station ) );
Brad_Park
Hi Jim,
This is Brad Park.
I've try to use it but somehow, I forgot how to make the list of value of specific column...
I'm trying to make a list of row (of specified column) with a each row () function.
Could you please tell me if there's better way to do it?
Thank you
Brad_Park
Thank you so much
2nd function was what I was searching for.
Thank you !
