OneNorthJMP
Level V
Auto Scaling of Variability Chart Y-axis based on USL & LSL spec limit
When there is outlier data, my chart is always being scaled to mix or max point, which make the chart not visible.
Is that possible to use JSL script to set the Variability Chart Y-axis dynamically based on the parameters USL & LSL limit that already embeded inside the parameters? Please advice. Thanks
15 REPLIES 15
Greenhorn
Re: Auto Scaling of Variability Chart Y-axis based on USL & LSL spec limit
Hi Jim,
Thanks for your support a lot!
I enhanced your code by this, for better looking graphs:
owr[i][AxisBox( 2 )] << Min( spec["LSL"] - 0.1 * (spec["USL"] - spec["LSL"]) ) <<
Max( spec["USL"] + 0.1 * (spec["USL"] - spec["LSL"]) ) << Inc( (spec["USL"] - spec["LSL"]) / 10 );
owr[i][AxisBox( 2 )] << Format( Best, 6 );
Is it something you also would do?
Or is there a more elegant way?
It looks fine to me. I am not exactly sure of other improvements, since I do not know the data.
Greenhorn
Doing so, I have the feeling, that it takes then longer to display the graphs.
Thanks again for your support!
Greenhorn
Greenhorn
How to handle "JMP Alert" in case I invoke only one item/ column?
The "for loop" causes this Alert
You need to check to see if you have the correct number of columns etc. before the code that causes the Alert, and then add the code necessary to deal with the issue.
