ThomasVH
Analyzing Repeated Measures Data in JMP® Software - masterthesis example
I was wondering if someone could verify if I took the right steps in setting up a mixed model for repeated measures for the following research:
In our research we had 2 groups of soccer players (amateur vs. professionals).
Each player of both groups performed 3 physical tests (a short vs. a long laboratory test vs. a field test), each test was performed on different days.Our outcome measure was VO2max (physical capacity).
Purpose: I mainly want to compare the VO2max between the amateur vs. professionals for each physical test. (2x3 table)
So I thought I should use a 2-way repeated measure ANOVA. In JMP pro 12-> a mixed model repeated measures.
But i'm not sure about which factor I should put in the fixed effect and/or random effect box when using Analyse -> fit model for my purpose.
Can someone please verify if I did the right thing in the two last pictures below? (The first picture is just a small selection from my data.)
Kind regards,
Thomas
12 REPLIES 12
Re: Analyzing Repeated Measures Data in JMP® Software - masterthesis example
I discovered that the nesting will impact your estimation. Instead of nesting, simply label your subjects uniquely as 1-8 instead of 1-4 within each kind of athlete. I attached a data table with the correct data levels and a Model table script for this analysis.
I apologize for the delay in this answer.
ThomasVH
Thank you for mentioning it. I tried it and indeed, it has also an impact on the p-values.
Greetings
ThomasVH
Everything went well. I'm only a little worried about my SEM values.
In most of the parameters for instance the VO2max (see picture beneath) the SEM values are the same for each group. Is this normal?
