nguyendv06
Adding up all the columns with names stored in a list
I have create a list of column containing roughly the same name below:
Xlist = {};
Ylist = {};
for(i = 1, i < ncols(dt2), i++,
if(
contains(dt2:i<< get name, "XXX") > 0, insert into(Xlist, dt2:i<< get name),
contains(dt2:i<< get name, "YYY") > 0, insert into(Ylist, dt2:i<< get name),
I would like to create a new column which will give me a sum of the Xcolumn and Ycolumn. It is not working well for me at all. I must not be doing something right.... Please help.
dt2 << New Column( "Xsum", Numeric, Continuous, Format( "Best", 12 ),
Formula(
sum(eval(Xlist)),
Re: Adding up all the columns with names stored in a list
The formula section within a New Column is not parsed and evaluated as one might expect.  I have found, that the best way to handle this, is to generate a literal string of the complete New Column phrase, exactly as you would want it if you manually typed it in, and then to execute that line.  The code below does that
dt2 = Current Data Table();
Xlist = "";
Ylist = "";
For( i = 1, i < N Cols( dt2 ), i++,
	If(
		Contains( column(dt2,i) << get name, "XXX" ) > 0, Xlist=Xlist || ":" ||  char(column(dt2,i) << get name) || ",",
		Contains( column(dt2,i) << get name, "YYY" ) > 0, Ylist=Ylist || ":" ||  char(column(dt2,i) << get name) || ","
eval(parse("dt2 << New Column( \!"Xsum\!", Numeric, Continuous, Format( \!"Best\!", 12 ), Formula( Sum( "||Xlist ||") ) );"));
eval(parse("dt2 << New Column( \!"Ysum\!", Numeric, Continuous, Format( \!"Best\!", 12 ), Formula( Sum( "||Ylist ||") ) );"));
Xlist = "";
Ylist = "";
	If(
nguyendv06
Wow Jim, thank you,
This works perfect.
