mjafari
Adding DATE properties to a column in JSL
Hi All,
I know we can add DATE stamp to any column in JMP for a time trend as following:
right click on any column-> choose column info->Column properties->Other->Type in "DATE" ->Insert the name of column including the dates
Is there a script to do that automatically?
Thanks a lot!
Moe
Re: Adding DATE properties to a column in JSL
All you need to do, is to add a new column property for the column, using the Set Property message
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
dt:name << set Property("DATE", "add whatever text you want");
