SpannerHead
Add values above a particular value to Missing Value Codes
I looked through the forum and I didn't see this posted.  I want to add all values in a data table that are greater than a particular value to be included as missing value codes.  The approach I was thinking of was to iteratively define all those values in a list and then add that list to the iteration like this.
Column( dt, colNames[i] ) << set property ("Missing Value Codes", {999, -999, 1e+13, 1.5e13, 2e+13, 3e+13, 4e+13, 5e+13, 6e+13, 1e+30, 2e+30, 3e+30, -5.5e+29, 9e+33});
Anyone figure this out?  If not, I'll work something out and post that.
Slán
SpannerHead
Re: Add values above a particular value to Missing Value Codes
Until we get this, you have to use something like you have described
Allow using limits in Missing Value Codes or provide new column property with same functionality
limit = 55;
m = dt[0, "height"];
high_rows = Loc(m > 55);
Column(dt, "height") << Set Property("Missing Value Codes", As List(m[high_rows]));
Write();
limit = 55;
Write();
SpannerHead
Added an iterative loop and colouring for the eliminated cells off to the races.
dt = Current Data Table();
colnames = dt << get column names( numeric,string );
meanlist = {};
For( i = 1, i <= N Items( colnames ), i++,
m = dt[0, colnames[i]];
high_rows = Loc(m > 1000000);
column(dt,colnames[i]) << Set Property("Missing Value Codes", As List(m[high_rows]));
column(dt,colnames[i]) << Color Cells("Red", high_rows);
Write();
Slán
SpannerHead
