Add blank space to differentiate groups visually
Dear all,
I created a Heatmap view in the Graph builder that shows the a performance metric for certain algorithms.
These algorithms are grouped.
Now I want to differentiate the groups more clearly, which means:
  1. I want to add spaces between the groups (better differentiation)
  2. I want to reorder the groups and/or columns (better visual story telling)
Is there a way to do this?9608_UserStudyResults_Tags_Usefulnes_L0_L1 (2).png
PS: I added the respective heatmap.
Thanks Michael
KarenC
Re: Add blank space to differentiate groups visually
If you move your "group" to the top of the graph builder (in the group x zone) then you can a drop down option "Graph spacing..." to put space between the groups.  You can re-order groups by using the column property "value ordering" to put the items in the desired order.
