Add Counter for Unique Cases in Groups
Hi all,
How can I write an integer value counter to increment unique values in column B within group A, to do this?
Here is what I have tried so far:
dt_Table1 = Data Table("Table1");
dt_Table1 << New Column("Dataset", Numeric, "Nominal", Set Selected);
Sum1 = dt_Table1 << Summary(Group(:Group, :Date));
Sum2 = Sum1 << Summary(Group(:Group));
:N Rows << Set Name("N Datasets in Group");
dt_Table1 << Update(
	with(Data Table(Sum2)),
	Merge Same Name Columns
Match Flag(0),
	Suppress foruma evaluation(0),
	By Matching Columns(:Group = :Group),
	Drop multiples(1, 0),
	Include Nonmatches(0, 0),
	Preserve main table order(1)
dt = dt_Table1;
For(i = 1, i <= :N Rows(dt), i++,
	While(Group_Number = GetValue(:Group[i]),
		N == Get Value(dt, :N Datasets in Group[i]),
		For(j = 1, j <= N, j++,
			:Dataset << Set Value == (j),
		Group_Number = Group_Number + 1,
Outputs:
11 REPLIES 11
hogi
Level XIII
Re: Add Counter for Unique Cases in Groups
amazing!
Depending on the structure of the table, many orders of magnitude faster :)
but still far away from a solution for the right click New Formula Column menu :(
dt = new table("Example",
New Column("A", character),
	New Column("B", character)
dt << add rows(20000);
for each row(
	:A = char(random integer(1,5));
	:B = char(random integer(1,1000));
t0 = hptime();
dt << New Column( "count",
	set each value(
		As Constant( Summarize( dt, bygroup = by( :a, :b) ) );
		N Items( Loc( bygroup[1], :a ) );
(hptime() -t0)/1000000; //~ 1min
t0 = hptime();
dt << New Column("C", set each value(
	Col Sum(Row() == Col Min(Row(), :A, :B), :A);
(hptime() -t0)/1000000; // < 1sec
hogi
Level XIII
happy news: JMP19 will provide Col N Unique()
https://community.jmp.com/t5/JMP-Wish-List/Col-N-Categories/idc-p/870972/highlight/true#M7292
and it will be available via the new formula column menu:
