hogi
Level XIII
AI + JSL
Thanks a lot  for your effort to make AI capable of programming JSL code.
The improvements over the last few months and weeks are incredible!
where did the improvements come from?
12 REPLIES 12
hogi
Level XIII
Re: AI + JSL
Read all code I provide before responding.
strongly depends on the LLM. Some LLMs are "greedy" - they don't dare to miss a detail.
Others:
I read the first 60 lines of code - there is more?!?
hogi
Level XIII
Re: AI + JSL
To make Vibe Coding more secure:
Safe mode - for Vibe Coding
hogi
Level XIII
Re: AI + JSL
## Trap 23: `<<Type("Dialog")` is NOT Modal — AI RECURRING FAILURE
> **This trap is responsible for repeated AI misdiagnosis.**
### Problem
The AI repeatedly assumes `<<Type("Dialog")` makes a window modal (blocking). It does NOT.
```jsl
// AI WRONGLY assumes this blocks:
New Window("My Tool", <<Type("Dialog"), ...)  // NOT modal!
New Window("My Tool", ...)                     // also NOT modal!
// Only these two block:
New Window("My Tool", <<Modal, ...)           // BLOCKS
New Window("My Tool", <<Type("Modal Dialog"), ...)  // BLOCKS
### Why the AI falls into this trap
The word "Dialog" SOUNDS like a blocking input dialog from other languages (Python's `tkinter`, C# `ShowDialog()`). In JSL, `<<Type("Dialog")` only changes the **visual style** of the window frame — it does NOT add any blocking behavior.
