Mickyboy
Level V
95% confidence intervals
Hi All,
l am trying to get a summary from a data table, l would like the mean of a variable l10t, the standard error, and 95% confidence interval. It all seemed fairly straight forward, but am having trouble with the 95% confidence intervals, have tried different ways to no avail, currently have
dt2<< Summary(
	Group( :Sample ),
	Mean( :dilution factor, :l10t ),
	Freq( "None" ),
	Weight( "None" ),
	Output Table( "log10t" ),
	Std Err( :l10t ),
	Confidence Interval( :l10t, 0.95),
	Link to original data table(0)
l am obviously doing something incorrectly, can anyone offer some advice.
Thanks Heaps
Re: 95% confidence intervals
You can accomplish something similar like this:
platform = dt << Oneway(
	Y( :height ),
	X( :sex ),
	Means and Std Dev( 1 ),
	Box Plots( 1 ),
	Mean Diamonds( 1 ),
	Mean Error Bars( 1 ),
	Std Dev Lines( 1 ),
	Connect Means( 1 ),
	Points Jittered( 1 ),
	Grand Mean( 0 )
Wait( 0 );
Report( platform )[Outline Box( "Oneway Analysis of height By sex" )][
Outline Box( "Means and Std Deviations" )][Table Box( 1 )] << Make Into Data Table;
Report( platform ) << Close Window;
Place your group variable in the X() role.
Mickyboy
Level V
Hi mzwald,
Thanks very much for your help and your suggestion, i tried this code
platform = dt2 << Oneway(
	Y( :l10t ),
	X( :fold dilution ),
	Box Plots( 1 ),
	Mean Diamonds( 1 ),
	Std Dev Lines( 1 ),
	Connect Means( 1 ),
	Grand Mean( 0 )
Wait( 0 );
and received the following error message
Cannot subscript Display Box in access or evaluation of 'Report(platform)[Outline Box("Oneway Analysis of height By sex")]' , Report( platform )[/*###*/Outline Box( "Oneway Analysis of height By sex" )]
however, l am almost there as to what i want to achieve for my data table with this,
dt2<< Summary(
	Group( :Sample ),
	Freq( "None" ),
	Weight( "None" ),
	Std Err( :l10t ),
	Confidence Interval( :Name ("Mean(l10t)")),
Loq = Data Table( "log10t" );
Loq << New Column( "Back T'sform Mean", Numeric, Continuous, Formula( Round(10^:Name ("Mean(l10t)"),0)));
Loq << New Column( "Back T'sform Std error", Numeric, Continuous, Formula(10^:Name ("Std Err(l10t)"), Format( "fixed dec", 6, 0 ) ) );
giving me this,
Data Table.PNG so l am almost there, l was hoping the confidence intervals would be a single simple line of code.
Thanks
Mickyboy
Well it looks like Summary doesn't currently support CI's, but you can always make a formula for them yourself.
The formulas for a 95% confidence interval (assuming a normal distribution) would be:
Upper95CI = mean + 1.96*stdev
Lower95CI = mean - 1.96*stdev
You can generate those two columns from the fields returned by the Summary platform. Those formulas will get you pretty close to what you are looking for.
Mickyboy
Level V
Hi mzwald,
i have used the following and has worked a treat
New Column( "Lower 95% CI", Numeric, Continuous, Formula ( Round(:Name ("Mean(l10t)") - (:Name("Std Err(l10t)") * t Quantile (0.975,23)), 4)));
if i have used the following to create a variable
dt2<< Summary(
	Group( :Sample ),
	Freq( "None" ),
	Weight( "None" ),
	Std Err( :l10t ),
and i would like to round the variable Mean(l10t), to four decimal places, can you do that from the above block of syntax???
thanks
Mickyboy
