lala
Level IX
这个脚本如何修改才能在工具栏的按键形式运行?
这个脚本能运行。
但将它放在工具栏的按键形式、却不能工作。
需要如何修改代码 ?
谢谢大家!
Re: 这个脚本如何修改才能在工具栏的按键形式运行?
Seems to be working fine for me (using JMP16.2 Pro on Windows 10).
dt = Current Data Table();
dt << Select Where(:age == 12);
d3 = dt << Subset(Output table("a12", Selected Rows(1), Selected Columns(0)));
You seem to be missing : from the column name, maybe Toolbar is more strict on the syntax? At least if I remove that from the toolbar script I will get this error:
but it will work fine from script editor (in my opinion it shouldn't)
lala
Level IX
OK、Thanks!
