Hi, thanks for finding our talk today. Hadley and I are going to be talking about making an easy button for data access. Now, this is a talk that we had given previously at a former Discovery Talk, and we're going to be talking about how you can extend this capability with our new OSI soft PI connector. Hadley, take it away.
Yes, that is absolutely right. Before I move into what we're going to be showing you today and what you can use yourself, I'd like to just introduce those of you who aren't familiar with the JMP Analytic Workflow. E veryone watching this talk likely already knows that JMP contains all of the analytic capabilities necessary to take any data that you have in any raw format and transform it into insight that can then be shared throughout an organization.
What we are going to be focusing on today is the data access and the data blending and cleanup aspects of the analytic workflow. Why are these important? Well, any problem- solving effort begins by collecting and compiling the data. One big problem, is that this can often be time- consuming and tedious, especially for scientists and engineers who have background in this stuff. What this effectively means is that it's often not done or not done in a timely enough manner. So problems can get unnoticed and problems, therefore, aren't solved.
The other problem is that data can be found in many different places, and it's an effort to grab all of this and put it in the right format, compile it together. A solution is an easy button for quick access to data wherever it is. What we have got and what we are going to show you is a simple interface built using the application builder, which is a simplified strip down option allowing people to press a button and get data from exactly where they need it in the format that they need to be able to solve their problems.
They can pick a data source and filter what is needed if necessary, even combining multiple sources and automating this. As Pete mentioned, what we're going to be doing is we're going to be building on a tool that we had previously shown which used SQL web APIs and even manual entries as well as combining data from other sources. Where have we shown this before? We've shown this in a previous Discovery Talk. So t hose of you watching this can look at the past Discovery presentations and check those out if you like.
What we are going to do now is take it one step step further from where we were back in 2022, and that is to extend it to data contained in OSIsoft PI servers. We're going to be making use of two features that were introduced in JMP 17. There's the Connect to the PI Server as well as the OSIsoft PI Wizard. With that, I'll turn things over to Pete to demonstrate that functionality.
Thank you, Hadley. Share my screen here. If I'm going to launch that PI importer, you'll find it in the same place you'll find all of the database connectors. Just like we would do for SQL, you'll go under file, database, and import from OSIsoft PI. You enter the name of your PI Server, your authentication method. Hit okay. Then it gives you this nice interface here and you can browse to what you're interested in and pick out a couple of attributes or tags that you want.
Let's just pick one for now. Then I can select what my start time is. I'm going to go back a little bit in time and shorten this query a bit so it goes a little quicker. Once you're ready, you can hit Import. This is a big improvement over what you had to do before, which involved a fair amount of scripting. But the nice thing here is once I've imported this, everything that I need to pull that up again is captured right here in the source script. So if I hit Edit, you can see all that was needed to be passed into that PI data source was right here. Hadley is going to take this now and start to make our easy button. I'm going to stop sharing and pass it back to Hadley.
All right, thanks for very m uch, Pete. I'm going to go ahead and share my screen once again and show you that what we are going to do is we're going to take that script that Pete just generated using the OSIsoft PI Import Wizard in JMP 17 and turn that into a simple add- in that literally anybody could use to select whatever tags they need and then grab that data. If you know what server it's coming from, you know what the configuration is, you're always grabbing the same data in exactly the same way, the only thing that might change is the tags, then this may be a stripped down simplified solution that anybody could use.
Of course, if you had other things that you wanted to filter on, like timelines and stuff, that's easy to include as well. And if you wanted to take this a step further and combine these data sources and maybe do some automation on them or automated analysis. That's an easy step from there, and Pete will show you how to do that a little bit later.
But what I'm going to do is I'm going to take the source script that was used to generate this data. I'm going to copy it and paste it into a JMP script. Now when I run the script, it goes back and collects the data from this tag IA right there . It could very well be that there are multiple tags that you would like rather than just one. Maybe you have a list of tags that you need.
What I'm going to do at first is I'm going to define a tag list which may contain the tag IA as well as IB and IC and as many more as I feel like including. This would be a good option, is if you were always getting the same tags every time. It didn't need to select them they're always the same.
Here they are. What I'm going to do is I'm going to run this for each one of these tags in this tag list. To do that, I'm going to make use of another relatively recent addition to JMP. Only I think it was added in 15 or 16, I'm not quite sure, but that's the For Each function. For each tag in my tag list, run this. My tag is going to be here. I nstead of running IA, we're going to just concatenate the tags and then go ahead and run that.
Excuse me. There we have it. It really is just that simple. It'll take a few seconds, but there we've got our text. That's a good solution if you were always running the same text. But if you wanted to take this functionality and extend it a bit to allow a user to select some tags using these configurations, I'm going to take this code and I'm going to run it or set it up in application builder.
Now, rather than hard coding a list, I'm going to ask the user to select the list from the list here. We'll just add a few tags to that. Let's add tag IA, IB, IC, and maybe one more kilowatt A. There they are. Now we'll just add a button that the user can press to grab whatever they've selected in the list and then get the tags. Button 1 is a good variable name, but we need a bit of a better descriptor so the user know what to do. There we have it. When we press this button, we are going to have it run the script that we just wrote. Of course, instead of getting our tags from this tag list, we are going to have it grab whatever a user selected from our list 1 list box.
Can it really be that simple? Yes, it can, and yes, it is. Of course, if we wanted to extend this functionality, at this point in the sky, our imagination and our needs are the limit. At this point, I will pass things back to Pete to show you how you can go ahead and do that.
Wow, Hadley, that really does look easy. Very nicely done. Why don't I share where we went from here? Actually, let me share this screen here. All I did was take what Hadley had shown and add a few more tags. The next thought is, "Hey, that's great that the PI importer is bringing in these tables individually, but what happens if I want to bring them together?" L et me just show what this does first. I'll do that data poll. This is what Hadley showed. Then I'm going to do the next step, which is a data compile.
Now, this takes advantage of the workflow builder, and we'll go ahead and walk through and actually write this since it's really easy to do. I'm going to just pick a couple of things to compile here. There you go. I'll show you how all of this was done. Okay, so basically, what JMP has done is it went through and it grabbed a bunch of those data tables, it concatenated them, then it split them apart, and all of these steps are here. So it concatenated those data tables, it split them apart, then it recoded those column names, and finally, it made just a simple report.
So let's walk through how we would do this inside of the workflow builder. I'm going to close out of these. I'll minimize this, and I'll just start with those three tables that were pulled from the data. Here I have IA, IB, and IC metrics that I'm looking at.
To start a workflow, you'll find it under File, New, and Workflow. A ll this is doing is it's grabbing stuff out of the log when I tell it to. If I hit record, it will capture all the steps that I do to any table manipulations, any joining or splitting of tables, any renaming or recoding of variables. All of that will be captured in here. Let's start with that.
The first thing I'm going to do is concatenate these. U nder the Tables menu, Concatenate. I have A there. I want to add B and C. I'll give it a name here. We'll just call this Stacked Data and hit okay. There you can see that this was stacked and it's captured here as well. Everything I needed to do there was captured. I want to back up here. You can see anything, while that recording is going on, is captured.
Let me back up, start over, show this one more time. With that off, it won't record anything. With that on, it will, so here, we'll do that. Tables, Concatenate again. I forgot to click one button there. I want to add a source name, so we'll do this again. Again, call this Stacked Data and hit okay.
T hat was my first step. Now, the next thing I'm going to do is split this apart because I actually don't want it stacked. I want them together in the same table, but I want to split it now. So we're going to go to Tables and Split. I want to Split by that source column, which is why I didn't have that in the first time I did it. Here we can see this. I'm splitting by source column. This is also a new feature here. It gives us a nice preview.
Now, this was something that I don't know about everyone else in here, but I used to struggle with this. I wasn't quite sure what I was going to get, especially with things like transpose and split, join some of the more complex table formulas.
Here I have all of my 500 rows of data for each of these different metrics, but what I'm missing is a time stamp. Without having that before, I might have done this wrong, but now I want to group this by time stamp. All of these now have a time stamp associated with that particular metric. Now I'm going to just call this Split Data and hit okay.
There, back to my workflow, you can see I've concatenated, I've split, but now I have this big ugly column name that I don't want. T here's a nice feature inside of JMP to recode these column names. I f I go to Columns and Column Names, there's a Recode Column Name, and this works just like recode for your normal data. I'm going to do a little advanced extract segment here. I want to pull out a portion that just looks at the very end, and that looks like the right values and I hit okay. Then I'm going to hit recode, and there we go.
Then the last thing you'll notice, again, this is all captured. The last thing I want to do here is make that graph. I'm going to just go graph and I'm going to grab those metrics, A, B, and C, and then map them out by timestamp.
Now, you'll notice one thing. This is not added to the workflow yet, so I can hit done and it's still not added. The reason that is, is I could still be making changes to this. Maybe I don't like this name. I might want to call it metric versus time. Maybe I don't like the format of these time stamps, so I can change that. But I'm doing all of these changes and the workflow doesn't capture it until I close this. When I hit Close, there you go.
I'm going to stop recording now and I will go ahead and close these two new tables that were made and show you that this works. There we go. Okay, so now you may be asking, "Well, why would I use a workflow? Why not just use a script? What's the advantage of that?" So l et's close out of this and show you why. I gave you an accidental preview of this earlier, but we'll show you here.
We're back to our application here. I went through and I pulled these three tags, and then when I concatenated them, it was looking for those three data tables with those three names. If I pulled different tags, so let's say I just want all of this data, so everything with an A at the end here, I'm going to do a data poll on. If I was using a script and I was looking for those specific data file names, the workflow or a script wouldn't work, but the workflow has this generalizability. If I look here in this concatenate tables, it's looking for three tables, IA, IB, and I C, and I don't have those tables open. I have AI open, but I have two other tables open. L et's see what happens when I run this.
It prompts me. It says, "Hey, what data do you actually want to compile? You have different data sources here." I actually want to compile these three that I have open. Now it says, "Oh, wait, I couldn't find the column names." Again, when I went through and I recoded columns, if I was running a script, it would potentially just wouldn't work because it didn't find that column name.
But here it says, "Hey, I can't find this column IB. Which one is that?" Let's just use a replacement column. There we go, and it worked. What this is doing is it has the ability to be generalizable with this reference. By default, a workflow has this ability to have a replacement reference, and I can manage this. Here you can see here are the tables, and I can prompt you to pick those tables. Then here are the columns that are referenced, s o I can have substitutes there.
Unlike a script, this will prompt you if it doesn't find what it's looking for. So it's very nice in that aspect. T hat was basically how to build a workflow and then use that to compile data and have it be generalizable. I'm going to pass it back to Hadley here for some closing thoughts.
Thanks very much. Let me just share my screen. In summary, making an easy button for data access solves some problems. It makes a lot of things easier. What it does is it addresses difficulties in assessing data because problems persist longer than needed. That's what happens when you don't have access to the data. Getting the data in the right format is really 80 % of a solution. Once you've gotten the data collected and formatted, compiled it, cleaned it, and then doing the rest of it is really the fun and easy part.
Creating these buttons allows data to be quickly and easily imported. It's possible to add filters, not something that we showed today, but if you go back and look at our... Well, I guess the selecting from the list was one of the filter options. Of course, you can always add others. You can see that from the previous presentation that we did back in 2022, as well as extending this to SQL, web API, and any other place that your data may be.
There are two add- ins on the community that we'd like to mention. There's the OSIsoft PI Importer as well as the PI Concatenator, you can find those things here. If you just Google these or look on our community, JMP. C ommunity.j mp.c om. Thank you very much.
