View Original Published Thread
Graph Builder: From Discovery to Presentation ( 2019-EU-TUT-144 )
Level: Beginner
Job Function: Analyst / Scientist / Engineer
Bill Worley, JMP Senior Systems Engineer, SAS
Graph Builder is a jack-of-all-trades when it comes to visualizing your data. It is useful throughout the analysis process, from exploring your data to understand what you've got, to discovering relationships, to crafting the perfect graph to present your results. This session will show you how to use Graph Builder effectively with an overview of the graph elements available and the options for each one. It will also show you some tricks to help you become a master graph builder.
Comments
Hi Bill,
some of your links to data like DinosaurusDozen referencing to your local file. May you can update your journal with either table script or adding these tables.
Thanks,
Martin
