Level: Advanced
Job Function: Analyst / Scientist / Engineer
Beatrice Blum blum_b_1, Senior Statistician, Procter & Gamble
Henning Vohwinkel vohwinkel0, Senior Product Developer, Procter & Gamble
Sanitary pads consist of different layers of raw material which are joined in a continuous production process. Various technologies are available to bond the top layer with the bottom layer. The requirement for the bonding is to keep the pad intact throughout the entire wearing time, even in extreme conditions at gym workout. Additionaly, the pad's flexibility and softness should be retained.
The case study discussed here will describe an attempt to combine two existing bonding technologies – gluing and thermoplastic fusion – in such a way that the finished pad remains stress-resistant while improving "pleasant" feel on skin. We will explain the team's decision making roadmap from problem definition to DoE finalization, including which constraints we had to respect, which performance targets we wanted to meet and why we chose to run a DSD eventually. Furthermore, we will discuss the DSD model building, Model selection via Auto-Validation and our final production process settings for the desired target.
![Image result for Women workout class](https://stylemagazines.com.au/wp-content/uploads/2017/11/feature-opt1-4.jpg)
(from: Brisbane's Best Fitness Classes For Women - Syle Magazines)
Sanitary pads should also stay laminated in work-out situations like above.
![Slide1.JPG Slide1.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16397i9A2951E31316CDA0/image-size/large?v=v2&px=999)
![Slide2.JPG Slide2.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16396i1BFF4918A1346A38/image-size/large?v=v2&px=999)
![Slide4.JPG Slide4.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16399i97407231B9E0C237/image-size/large?v=v2&px=999)
![Slide5.JPG](/skins/images/421362A7EA36D41914DBBD616B6A4872/responsive_peak/images/image_not_found.png)
![Slide6.JPG Slide6.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16401i7A85D1A8F5F25BF8/image-size/large?v=v2&px=999)
![Slide7.JPG Slide7.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16402iFE1E863D8761B588/image-size/large?v=v2&px=999)
![Slide8.JPG Slide8.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16403iF1332ABD50801C63/image-size/large?v=v2&px=999)
![Slide9.JPG Slide9.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16404iB009954FA511BD78/image-size/large?v=v2&px=999)
![Slide10.JPG Slide10.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16405i703773BF9A902949/image-size/large?v=v2&px=999)
![Slide11.JPG](/skins/images/421362A7EA36D41914DBBD616B6A4872/responsive_peak/images/image_not_found.png)
![Slide12.JPG Slide12.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16407i7DD48B35077E79B2/image-size/large?v=v2&px=999)
![Slide13.JPG Slide13.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16408i9B8870D79F066D44/image-size/large?v=v2&px=999)
![Slide14.JPG Slide14.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16409iA44E7486839B3815/image-size/large?v=v2&px=999)
![Slide15.JPG Slide15.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16410i69BCC93C88EDDC70/image-size/large?v=v2&px=999)
![Slide16.JPG Slide16.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16411i5DE8F3B7644F4FB0/image-size/large?v=v2&px=999)
![Slide17.JPG Slide17.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16412i88806BF2F0310E59/image-size/large?v=v2&px=999)
![Slide18.JPG Slide18.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16413i59E5C660608D1383/image-size/large?v=v2&px=999)
![Slide19.JPG Slide19.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16414i91170ABCF9FFC436/image-size/large?v=v2&px=999)
![Slide20.JPG Slide20.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16415i9A3DC0BEFE249503/image-size/large?v=v2&px=999)
![Slide21.JPG Slide21.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16416i664E3D3353E7D64B/image-size/large?v=v2&px=999)
![Slide22.JPG Slide22.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16417i8978D4F1ABAA94D7/image-size/large?v=v2&px=999)
![Slide23.JPG Slide23.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16418i576CAEBB32E36B70/image-size/large?v=v2&px=999)
![Slide24.JPG Slide24.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16419iEA30ADEBE2C5D982/image-size/large?v=v2&px=999)
![Slide25.JPG Slide25.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16420iCDC86F1D5B3396D0/image-size/large?v=v2&px=999)
![Slide26.JPG Slide26.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16421i4FA4E52CBB6D6670/image-size/large?v=v2&px=999)
![Slide27.JPG Slide27.JPG](https://community.jmp.com/t5/image/serverpage/image-id/16422i5710682DA24FEED9/image-size/large?v=v2&px=999)
