Using JSL to Develop Efficient, Robust Applications (EU 2018 415)
Level: Advanced
Joseph Morgan, JMP Principal Research Statistician Developer, SAS
This session will focus on JSL constructs that can prove invaluable when developing efficient, robust, production-ready applications. These include expression handling functions, xpath support, namespaces and others. The ideas will be illustrated with examples that the instructor has collected over the past 10 years as he has worked with a wide cross-section of JSL users.
Comments
thomasz
 The download links do not work
@ colleagues:
the presentation and  the JSL file are available at the bottom of this page
Video is not available anymore?
thanks for recovering it  : )
#1 Expression handling
#2 clever Display Tree Indexing
Just imagine how powerful Jmp/JSL will get via #1 X #2:
Expression Indexing: read and write access
... or even Expression Xpathing?
tMinnx
Exp() function and its family are too hard to understand even after spending hours looking at the script and Log. It is not intuitive at all. I would love to watch additional videos elsewhere explaining the practicality of these functions.
E.g.
x = Expr(Expr(Expr(1+2)));
gives a result when I assume it is simply an assignment of a variable "x" to an expression. My intuition is no result from that line.
Hm, I partially agree:
I'd love to see more videos about Expression Handling
On the other Hand:
this video IS THE key - your chance to understand the concept. It's definitely worth to watch it 2-3 times.
It's a good practice to predict what's going on - and then to compare with the actual result. I guess every JSL programmer uses this approach to find the final, working result. Put an Eval Expr here, try Name Expr there ...
Another aproach: use another Name which facilitates to remember the functionality.
  • Name Expr() could be renamed Hey JSL Symbol(Name), give me your Expression().
  • Expr() might be safety Zone, don't Touch()
For your example,
z = Expr(Expr(Expr(1+2)));
IS assigning ...
an expression to a variable z:
and the assigned expression is Expr(Expr(1+2)).
A third aproach: If you wonder why it's so complicated - think if there is an easier way to get the same result (with less Expr, Eval Expr, Name Expr , ...).
After guessing such an alternative approach, try IT and check if it really works ...
If it doesn't work - compare with the original approach and draw your conclusions.
*) This is what puzzled me a bit:
Expr() works as  safety Zone, don't Touch(). OK.
But inside an Eval Expr() the same Expr()  acts like:
HERE I am, please evaluate! - and keep the rest untouched()
Kind of the opposite  : )
x= Expr( 1 + 2);
y = Eval Expr (Sin(4) + Expr(1 + 2));
The issue:
the individual JMP programmer defined if a function evaluates it's argument or not.
There is NO documentation!
e.g. Does Head evaluate its argument?  - who knows?
To make our work live much easier:
JSL editor could help us tremendously - by indicating which function evaluates it's argument and which one doesn't - and which one does just something Name Expr ()-ish.
Let's hope that the wish gets enough Kudos:
Advanced syntax highlighting in JSL Editor
... and the attention of JMP developers to implement it.
there is a chapter in the scripting index:
https://www.jmp.com/support/help/en/18.0/?os=win&source=application#page/jmp/advanced-expressions-ma...
Here is a Webinar video explaining an application case in detail:
Run a Platform without Knowing the Number or Names of Columns
@Ryan_Gilmore , the video disappeared again.
Is it possible to recover it another time?
thank you
Great presentation. I think "syntactic sugar" is my favorite new expression!
