Poster by JMP Developers Brian Corcoran BrianCorcoran and Heman Robinson heman.robinson. This presentation gives four examples of Interactive HTML reports (Distribution, Fit Model Profiler, Bivariate and Bubble Plot) you can create in JMP and share with people who do, or do not, have JMP installed. To run the interactive reports from the PowerPoint file, unzip all the files into the same directory. When you click on the link in the PowerPoint, a browser containing the report will open. Please note that the Bubble Plot uses a large data set, and may take a while to render.
