The JMP Journal can be used to steer the steps of an analytic workflow. The data case study presented here come from a home analytics sensor array Developing a standard workflow can streamline the time consuming parts of any data analysis project: Import, pre-processing, and cleanup. This is an effective way to work in JMP where the analysis steps are constant, but the data set is constantly changing due to new sensor values being collected.
