View Original Published Thread
Compare Designs: A New DOE Capability in JMP® 13
Bradley Jones, PhD, JMP Principal Research Fellow, SAS
The Evaluate Design capability is a useful tool in for DOE diagnostics. However, there are often cases where an investigator would like to compare the properties of two or three designed experiments before choosing one to actually run. There are two cases where this may prove useful. The first is comparing designs having the same number of runs but generated using different criteria. The second is comparing designs having different numbers of runs to evaluate whether the extra runs are worth the extra cost. This talk provides examples of both cases with advice about how to use this new feature to best advantage.
Comments
manny_uy
Would you share thejournal so that I can exercise the Compare Design with your data sets?
Manny
Discovery Summit 2016 Resources
Discovery Summit 2016 is over, but it's not too late to participate in the conversation!
Below, you'll find papers, posters and selected video clips from Discovery Summit 2016.
