Design of Experiments Club Discussions
Recordings DOE Club Q2 2024
Thanks to all participants! Please feel free to elavorate more or ask questions below.
Video 1: What are the consequences (logically and mathematically) of not following the DOE in the order specified? - Richard Lacaba
(view in My Videos)
Comments
@Victor_G  - You can record the order of the experiments in the table and see if you have an effect of the experiment order on the response.
@bdclark23  - I get this question often and provide this from Montgomery to my clients: Randomization is the cornerstone underlying the use of statistical methos in experiment design. By randomization we mean that both the allocation of the experimental material and the order in which the individual runs of the experiment are to be performed are randomly determined. Statistical methods require that the observations (or errors) be independently distributed random variables. Randomization usually makes this assumption valid. By properly randomizing the experiment, we also assist in “averaging out” the effect of extraneous factors that may be present.
Video 2: Augment Design (Sequential DOE) - John Szarka ( @jszarka )
(view in My Videos)
Question from Thalita Coppini Soares ( @THCS :( Could you run different ranges of the variables from the 1st experiment in this scenario?
Answers:
@Jonas_Rinne  -  Yes you can change that as well if needed.
@Victor_G  - Yes, you can change the ranges of the factors. This enables to focus in the optimal area (reduce the range, restrict the experimental space) or move the design space a little further if you have no interesting area to search/optimize for
@Paul_J  - Or maybe adding a new factor with the next set?
@Jonas_Rinne  - Here is a community post where you can check out how to do that: Solved: How do I add a new continuous factor to a DoE via design augmentation? - JMP User Community. Note that this factor had to be constant in your previous experiments.
Question from Thalita Coppini Soares ( @THCS :(  so, start with a PB to reduce the number of experiments, and then run a full design just with the main factors with narrow ranges?
Answer
@Victor_G  - Or with another screening design, in the example here DSD could be helpful: no constraints and high number of continuous factors, so it could help better estimate main effects and possibly detect interactions and quadratic effects.
And once your screening is done, why not adding higher order effects (interactions, quadratic effects, ...) in the augmentation on the narrow ranges to expand your knowledge about the system and have a better/more accurate model?
Video 3: Is it reasonable to keep main effects in the DoE Model even when they're not significant? How reliable is the effect size estimation of these "insignificant" factors? - Johann-Christoph Dettmann ( @JohannD124 )
(view in My Videos)
Video 4: Integration of DOE with other methods: ML, chemoinformatics, etc... - Victor Guiller ( @Victor_G )
(view in My Videos)
Comments
@ruskicar - SVEM (self-validating ensemble modelling) is an approach that is sometimes used to model space-filling DOE’s
@Victor_G - Design of experiments and machine learning with application to industrial experiments | Statistical ...
Statistical Papers - In the context of product innovation, there is an emerging trend to use Machine Learning (ML) models with the support of Design Of Experiments (DOE). The paper aims firstly to...
Design choice and machine learning model performances - Arboretti - 2022 - Quality and Reliability E...
@Paul_J  - Can JMP "optimal" designs be based on mechanical models?
@maria_astals - Space-Filing Designs: https://www.jmp.com/support/help/en/18.0/index.shtml#page/jmp/overview-of-spacefilling-designs.shtml
@Victor_G   - Example of Space-Filling designs with Support Vector Machine analysis on mixture design : https://community.jmp.com/t5/Online-Abstracts/Synergy-Between-Design-of-Experiments-and-Machine-Lear...
Video 5: Modeling DoE results which include whole plots, especially the random error added to the Whole Plot effect. - Drejc Kopač ( @ruskicar )
(view in My Videos)
0 REPLIES 0
