Check out the JMP® Marketplace featured Capability Explorer add-in
Finding and Telling Stories Using Data Visualization Featuring Kaiser Fung - Tuesday, May 8, 2018
Date: May 8, 2018
Time: 9:00 am - 2:30 pm
Location: The Brown Palace Hotel, 321 17th Street, Denver, CO 80202
Registration & Lunch: Free
Data visualization – when done right – can transform not only the way you present results to colleagues and other stakeholders in your organization, but also the way you explore and analyze the data itself. That's why you can't afford to overlook the benefits of linking graphics to statistical analyses. Dynamic visualization helps researchers find and construct a narrative around linkages between variables in even the most complex data sets.
In this seminar, you will walk through a series of cross-industry case studies showcasing the ways in which visualization boosts both presentation and analysis. You will learn how to:
Make effective visual displays.
Find a story in a raw data set.
Turn chart-making from a job requirement to a professional advantage.
Register now to attend in Denver - https://www.jmp.com/en_us/events/seminars/explorers/explorers-dataviz-08may-denver.html
0 REPLIES 0
