Hi @TM,
For more context, what reason would there be for adjusting the compression force based on the formulation? Is it to ensure you get some form of material/success at the end (i.e. Compression Force of 1 wont work when Factor A is set to 0, but work when set to 10).
Thanks,
Ben
