Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
wenwenzhou
How to creat one wafer map
I have a set of EXCEL data, how to use this set of data to draw a wafer diagram in JMP
Manlio
Re: How to creat one wafer map
To create a wafer map you can give X and Y coordinates of die and then plot them using graph builder and you could use heatmaps to highlight defects for example.
We have an example of this in the STIPS course, Module 2: Exploratory Data Analysis. Here is the link, watch from minute 2:15: Creating Maps Using Coordinates - JMP User Community
I have also attached the data file example.
Hope this helps!
Manlio
I will point you to the JMP Addin called the Semiconductor Toolkit.  It can be found under the File Exchange option at the top of this webpage.
