New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
cmobrien15
Level I
Can the Pass/Fail columns be overwritten when new spec limits are updated?
In a data-table,  can the Pass/Fail columns be overwritten when new spec limits are updated?
I need "P" or "F" to be overwritten  for every row.....in each Pass / Fail column (associated with each test).
If someone has a jsl script for this,.... that would be perfect >
1 REPLY 1
WebDesignesCrow
Re: Can the Pass/Fail columns be overwritten when new spec limits are updated?
Hi @cmobrien15 ,
I think it is do able through JSL as long as the Pass/Fail is a formula column.
Steps would be;
1. Existing dataset with existing spec limit & existing pass/fail formula columns
2. Replace the spec limit with new limit
3. Pass/Fail formula column updated
If can complete above steps manually, you can refer the JSL scripts in the workflow builder or log.
However, I'm not sure how many pass/fail columns that you have.
The Pass/Fail column is based on conditions that;
- If any of test fail considered fail? or must fail every test to be considered fail?
- Pass/Fail column for each test?
