Colorado JMP Users Group Discussions
Using Experimental Design to Increase Predictability, Optimize Processes and Lower Costs @ JW Marriott Denver Cherry Creek, 150 Clayton Ln., Denver
Great opportunity -- LECTURE & LUNCH -- Wed., April 10, 2019
Date: April 10, 2019
Time: 9:00 am - 3:00 pm
Location: JW Marriott Denver Cherry Creek, 150 Clayton Ln., Denver, CO 80206
Registration & Lunch
: Free
See Agenda
Design of experiments (DOE) is a data-driven strategy that helps practitioners to better understand the underlying behavior of a system by identifying those factors that most affect desired outcomes. By optimizing your experimental design, you can more effectively take covariate information into account when setting up an experiment.
In this one-day seminar, DOE expert Bradley Jones will show how you can accelerate learning cycles with a new, more flexible method for experimentation. He’ll demonstrate how to use optimal designs which reduce the cost of experimentation, accommodate multiple types of factors and can be optimized when the design space is constrained.
0 REPLIES 0
