Share your analytics insights with fellow JMP users. Submit a brief abstract to the Discovery Europe call for content describing innovative ways you use JMP.
Christian Ramskov Larsen's Blog
ChristianBille
Level IV
JMP Hands on Workshop - Intro to Design of Experiment
When: May 5th from 10.00 - 11.00
Christian Ramskov Larsen and Phil Kay will guide you through this online session. You will also need a working version of JMP to follow along in the workshop. If you don’t already have a full JMP license installed on your system, you can download a 30 day free trial version here: https://www.jmp.com/en_us/download-jmp-free-trial.html Read more and sign up for free here: Sign up!
The Journal used in the workshop is attached here.
JMP Hands On Workshop – Intro to DOE
Intro Information Slide: Se PDF
Tata Steel case: https://www.thechemicalengineer.com/cpd/webinars/enhanced-product-development-through-experimental-d...
Learn (DoE) JMP overview Link: https://www.jmp.com/en_dk/events/getting-started-with-jmp/overview.html
Q&A from event May 5th – see pdf.
Last Modified: May 6, 2020 6:18 AM
Comments
