Ben Francis' Blog
Predictive Modeling for Smarter Business Decision Making 17th Sept 2020
Recently I had the pleasure of giving a webinar on using JMP to make smarter business decisions to over 200 registrants. JMP and JMP Pro usage has led to positive business impacts globally, two were highlighted within the webinar:
(view in My Videos)
  • The dataset used in the webinar is attached below. Is this the sort of data that you could collect in order to understand your processes?
  • Also below is the model comparison for Breakage Rate that was used. What are your thoughts on the best model for Breakage Rate?
  • The wider report on the Breakage Rate outcome is available via JMP Public. How do you feel this report could be improved?
Have you considered how JMP Pro modelling techniques working in conjunction with subject matter expertise could positively impact your business/industry? Please do get in touch if you'd like to discuss how JMP Pro can help you with your specific goals.
Last Modified: Sep 22, 2020 10:57 AM
