JMP® Live Demonstration
This tutorial focuses on publishing, interacting and sharing your reports using the Tablet Production sample data featuring column switcher, local data filer and prediction profiler.
Source Data
Tablet Production from Sample Data
Analyze Distributions
Distributions, frequencies and descriptive statistics of both categorical and continuous variables with local data filter.
Bivariate Fit of Dissolution by Mill Time
Bivariate plot of response variable dissolution and other continuous variable predictors using column switcher.
Response Dissolution
Fit predictor variables to model of Dissolution using Prediction Profiler.
JMP Live Demonstration.zip
