Learn the basics of using JMP at your own pace. Getting Started Resources to move you forward on your analytics journey. Getting started with JMP is easy. Use these resources to get the most out of JMP, right from the start.
See how to navigate the JMP menus and data tables, import data into JMP, summarize and graph data, and perform basic statistical analyses.
Basic Navigation Part 1: JMP Interface, Summarizing and Graphing
Basic Navigation Part 2: Getting Data Into JMP and Saving Your Work
Part 3: Basic Analysis and Integrated Graphs
Getting Started Parts 1, 2, 3.
