More Unsupervised Engineering: Hacking the Short Run Control Chart
So, let’s just say the quiet part out loud: If you’re strict about it, semiconductor manufacturing data as it comes out of the databases shouldn’t be on typical control charts. For many, many reasons. But fear not! There is a solution. Join Mike Anderson as walks through a case study showing the pitfalls of using standard control charts with semiconductor data and how to address them using the new short run control chart introduced in JMP 18.
