The Python interface to Query Builder provides a convenient mechanism to build your own custom data connector and still use the querying capabilities within the JMP interface. But, is it so easy to use that you can build a complete connector in a single Discovery talk? See for yourself in this fast-paced session that should give you enough information to return to work to build your own data connector.
