Clean Up Error Codes
John_Sall
For outliers. Clean Up Error Codes looks for strange, outlying values that are not part of the regular data. Values like these are frequently used to indicate error conditions in measurements.
The add-in uses an interquantile range to identify these values, looking for values that are far away from the upper and lower ends of the range.
Comments
kwalter1
I don't understand how to use this. Nothing happens for me.
kwalter1
Figured it out. I just didn't have any outliers.
How can one change this to have a by button. I would like to check for outliers for weight by age, for example.
