Timothy Marsh holds a Ph.D. in macromolecular science and engineering and is a Research Associate in Corporate S&T at PPG. His work spans coatings formulation, electrodeposition physical chemistry, and experimental design. He currently coordinates PPG’s Sigma Logic™ training program, teaching DOE and statistical thinking using JMP, while also supporting digital transformation initiatives and consulting on applied research projects and field root cause investigations.
