From JMP Live, can I share the data table used in a JMP Live report?
Yes, you have the option to share the data with those who have permission to access the JMP Live report. In his Mastering JMP session on collaborating using JMP Live, @HydeMiller explains.
The information button shows 1) which groups can access the report 2) when the report was last updated and 3) a link to the data table if the author has made it accessible.  The ability to share the data allows you to use the JMP Live report as a sort of repository of the most recent data, alleviating the need to send the table to others after it is updated.
