Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Using Multivariate Methods to Explore Data
Learn to use statistical tools to explore and describe multidimensional data. Quickly and easily identify correlations between variables. Uncover and remove outliers to prevent them from biasing results, or extract them for further investigation. Group observations that are most similar to each other, and reduce the number of variables in a dataset to describe features in the data and simplify subsequent analyses.
Comments
abmayfield
Highly recommend this presentation, as he makes an excellent case for using multivariate approaches and shows how easily they can be undertaken in JMP.
SE_0785
Hi Phil,
Quick question. For the multivariate correlation matrix, it assumes a normal distribution, correct? So, do we need to transform any non-normal distribution before we run the analysis? Thank you..!
