New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Extract Statistics from an Analysis into a Report
Problem
You run an analysis in JMP and want to extract some of the statistics from the platform report. Then you want to place those statistics into a custom report window, so that you can keep those after the data table and platform report are closed.
Solution
You can get a reference to the report layer of the analysis report and use JSL messages to extract statistics out of
In this example, a Bivariate platform report is generated and you get a reference to the report layer (reportbiv). Using that reference, you can extract variables and strings out of the Bivariate report. Then a new custom report window is created and populated with the statistics and strings that were extracted from the report. Finally, the data table is closed, which closes the Bivariate report, but the custom report window stays open.
Names Default To Here(1);
sd = Open( "$SAMPLE_DATA/Lipid Data.JMP" );
biv = sd << Bivariate( // biv is the analysis layer.
	Y( :Triglycerides ),
	X( :LDL ),
	Density Ellipse( 0.95, {Line Color( {213, 72, 87} )} ),
	Fit Line( {Line Color( {57, 177, 67} )} )
/* Get a reference to the report layer. */
reportbiv = biv << Report;
// Make sure the "Bivariate Normal Ellipse" outline
// in the Bivariate report is open. You can then see which
// content to extract into the Custom report.
reportbiv[Outline Box( "Bivariate Normal Ellipse P=0.950" )] << Close( 0 );
// Extract the correlation coefficient.
corrvalue = reportbiv[Outline Box( "Bivariate Normal Ellipse P=0.950" )][Number Col Box( "Correlation" )] << Get( 1 );
// Extract the numeric values from the Summary of Fit report as a matrix.
sumfit = reportbiv[Outline Box( "Summary of Fit" )][Number Col Box( 1 )] << Get as Matrix;
// Extract the Term column of the Parameter Estimates report as a list of strings.
term = reportbiv[Outline Box( "Parameter Estimates" )][String Col Box( "Term" )] << Get();
// Extract the Parameter Estimates values as a matrix.
parmests = reportbiv[Outline Box( "Parameter Estimates" )][Table Box( 1 )] << Get as Matrix;
dlg = New Window( "Custom Report",
	Outline Box( "Selected Values",
/* The Lineup box defines a two-column layout, each of which contains a Text Box. */
		Lineup Box( N Col( 2 ), Text Box( "Factor of Interest: " ), Text Box( term[2] ), ),
		tb = Table Box(
/* Display an empty string in the first column and the text in the second column. */
			String Col Box( " ", {"Sample Size: ", "Adjusted RSquare: ", "RSquare: ", "Correlation:"} ),
/* Insert a 30 pixel x 30 pixel spacer between the columns. */
			Spacer Box( Size( 30, 30 ) ),
/* Display an empty string in the first column and the statistics in the second column. */
			Number Col Box( " ", sumfit[{5,2,1}] |/ corrvalue )
/* Insert a 1 x 30 spacer. */
		Spacer Box( Size( 0, 30 ) ),
		Table Box(
/* Display the cloned String Col Box and insert the Parameter Estimates and Standard Error values. */
			String Col Box( "Term", term ),
			Number Col Box( "Estimate", parmests[0,1] ),
			Number Col Box( "Standard Error", parmests[0,2] )
tb << Set Shade Headings( 0 ); // Turn off shaded table headings.
tb << Set Heading Column Borders( 0 ); // Turn off table column borders.
Close( sd ); // Close the data table.
Discussion
JMP platform reports contain two layers: the platform layer and the report layer. If you have a JSL object that is a reference to the platform layer, you can send messages to that object that relate to the analysis. These are generally options that are found in the red triangle menu. If you have a JSL object that is a reference to the report layer, you can send messages to that object that relate to the report itself. These messages can extract values or images, change selections, open and close outline nodes, among other actions.
See Also
This article is based on an example in the JMP documentation.
Comments
eliyahu100
I tried to follow this code and use it in a different report.
my intention is to run several models and summarize the important results in a table the way it is shown here.
Here Is a simple example on a sample dataset to show what I’m aiming for.
For starts I tried to extract the P-value of the model. So I commented out the second model and wrote the following code:
Open("$SAMPLE_DATA/Detergent.jmp");
Model1 = Fit Model(
       Y( :previous use ),
       Effects( :softness ),
       Personality( "Nominal Logistic" ),
       Run(
             Positive Level( "yes" ),
             Likelihood Ratio Tests( 1 ),
             Wald Tests( 1 ),
             Odds Ratios( 1 ),
             ROC Curve( 1 )
reportMod = Model1 << Report;
FMchi = reportMod[Outline Box( "Whole Model Test" )][Number Col Box( "Prob>ChiSq" )] << Get( 1 );
dlg = New Window( "Custom Report11",
		Table Box(
			String Col Box( "Pvalue", FMchi )
Model2=Fit Model(
       Y( :previous use ),
       Effects( :count ),
       Run(
             Wald Tests( 0 ),
             Odds Ratios( 1 ),
             ROC Curve( 1 ),
             Logistic Plot( 1 )
The final table I want is:
Attribute
Whole Model Test
RSquare (U)
N
Estimate
Prob>ChiSq
Odds Ratio
AUC
softness
1.000
0.000
24
0
1.000
1.000
0.500
count
0.5268
0.012
24
0.0183
0.5301
1.01847
0.5625
here is a screen shot of the report obtained in which I highlighted the data extracted.
(In attribute softness, for parameter estimate and odds ratio I took only the first row from the journal).
The original report window shows up but i didn't even get the additional report window to open.
Any tips would be appriciated.
TIA, Eli
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
