Keyword arguments for functions
I would love if in User Defined funcitons we could use keyword arguments in the calls so I can do
Names default to here(1);
f = function({x, y=2, z=3},
	show(x, y, z);
print("What I'd like to do");
f(1, z=2);
//I want it to be 1, 2, 2
//instead of having to do
f = function({x, kwargs={}},
	{DEFAULT LOCAL},
	// optional
	y = 2;
	z = 3;
	evallist(kwargs);
	show(x, y, z);
print("Using List");
f(1, {z=2});
Someone mentioned it here, but it was 8 years ago, so figured I'd bring it up again.
14 Comments
gzmorgan0
Super User (Alumni)
@vince_faller
Cool example. Thanks for Sharing. Typo correction
show(f(2, {y=14})); // 36 not 33
hogi
Level XI
How are the standard Jmp functions defined,
- such that close accepts an supplementary argument noSave.
- such that add column accepts the expression Formula(...) at any position within (...)
dt << New Column( "X", Formula( row() ) );
Instead of
f(2, {y=14})
could
f(2, y(14))
be the way how it should look like?
Craige_Hales
The internal functions are built in C++, not JSL. The user functions (in JSL) are interpreted by other C++ code that chooses how to  turn arguments into parameters (where the arguments to a function are the external values passed in and the function's parameters are the internal variable names that refer to the values.)
A function like sin(A), written in C++, looks something like
ExpressionPointer sin( ExpressionPointer E) {
   double value = evaluateExpression( E );
   double answer = sin( value );
   return makeExpression( answer );
The expr() function in JSL, where the function just returns its argument without studying it, looks something like
ExpressionPointer expr( ExpressionPtr E ) {
   return E;
That seem useless at first glance, but it allows the assignment operator to evaluate the right-hand-side of
ex = expr( a + b );
and store an expression tree into ex rather than the result of a+b. A more interesting example is the head(a+b) operator.
ExpressionPointer head( ExpressionPointer E ) {
   return MakeExpression( E->child );
That's a crude approximation of the idea: an expression tree for a+b has a root, +, which has two children, a and b.  E->child is getting the root, +, and returning that as an expression with no children.
The JMP developers made a decision to hide that complexity in the JSL user written functions to make the 99% use cases easy to write. Most of the languages I'm familiar with don't have expressions that can be manipulated (Snobol does, sort of, and that explains JMP's patmatch() function...) Using a list is a reasonable approach to sending an expression to a function; the list is evaluated...to the same list. The function is working on a copy of the list.
