Many times color values are specified in many industries through hexadecimal numbers.
See:
https://htmlcolorcodes.com/
This function facilitates the conversion of hexadecimal color values into JMP Color values
/* Return the JMP Color number from an input of a 6 character */
/* hexadecimal string. */
/* March 2020 */
/* Jim Nelson */
/* Purpose: Many times color values are specified in many */
/* industries through hexadecimal numbers. */
/* See: https://htmlcolorcodes.com/ */
/* This function facilitates the conversion of */
/* hexadecimal color values into JMP Color values */
/* Usage return = HexToJMPColor( "HexVal"); */
/* Example jmpColor = HexToJMPColor( "AA45AF"); */
HexToJMPColor = Function( {HexString},
{DefaultLocal},
// Must be 6 characters in length, and contain only
// the characters 0123456789ABCDEFabcdef
If( Length( HexString ) == 6,
errVal = "";
For( i = 1, i <= 6, i++,
If( Contains( "0123456789ABCDEFabcdef", Substr( HexString, i, 1 ) ) == 0,
errVal = errVal || "2",
errVal = errVal || "1"
// If errors have not been found, calculate the JMP Color
If( Contains( errVal, "2" ) == 0,
JMPColor = RGB Color(
(Hex To Number( Substr( HexString, 1, 2 ), 16 )) / 255,
(Hex To Number( Substr( HexString, 3, 2 ), 16 )) / 255,
(Hex To Number( Substr( HexString, 5, 2 ), 16 )) / 255
// If the number of input values is not 5 then return a list of
// 3's at the same lenght of input string
errVal = Repeat( "3", Length( HexString ) )
// If the error checks did not return no errors, set
// the JMP color to a value that will prodive the
// calling program a key to what is wrong
// A positive number indicates an error was found
// A string of all 3's indicates a wrong lenght hex
// was passed in
// A string of 1's and 2's indicates that each position where
// a 2 is returned, an invalid value was input
If( Num( errVal ) != 111111,
JMPColor = Num( errVal )
// Return the calculated value
JMPColor;
jc = HexToJMPColor( "aa45af" );
If( jc < 0,
New Window( "Example",
Graph Box(
Pen Color( "Black" );
Pen Size( 2 );
Fill Color( jc );
Oval( 15, 75, 65, 55, 1 );
