  • JMP 19 is here! See the new features at jmp.com/new.
  • Register to attend Discovery Summit 2025 Online: Early Users Edition, Sept. 24-25.
Custom Map Shape Files for the Regions of Peru
Here are custom map shape files for the Regions of Peru.  To make these files available for whenever you want to build a geographic map, copy the -Name.jmp and -XY.jmp files to the directory shown below.
  • On Windows: C:/Users/<user name>/AppData/Roaming/SAS/JMP/Maps
  • On macOS: /Users/<user name>/Library/Application Support/JMP/Maps
Also included in the ZIP file is a demonstration JMP data table.  This data table has an embedded script that will generate a geographic map of Peru.
For more information about custom map shape files, search for the topic “Custom Map Files” in JMP Help.
Comments
Raj
hai will you teach me how u plot this script..
