Custom Map Shape Files for the Provinces of Costa Rica
Here are custom map shape files for the Provinces of Costa Rica.  To make these files available for whenever you want to build a geographic map, copy the -Name.jmp and -XY.jmp files to the directory shown below.
  • On Windows: C:/Users/<user name>/AppData/Roaming/SAS/JMP/Maps
  • On macOS: /Users/<user name>/Library/Application Support/JMP/Maps
Also included in the ZIP file is a demonstration JMP data table.  This data table has an embedded script that will generate a geographic map of Costa Rica.
For more information about custom map shape files, search for the topic “Custom Map Files” in JMP Help.
