BookmarkSubscribeRSS Feed
russ_wolfinger
May 27, 2014
Venn Diagram
This add-in constructs Venn diagrams with either constant or proportional areas.  The former accommodate up to five variables and the latter are limited only by the distribution of the counts corresponding to the variables.
The proportional-area diagrams call methods kindly provided by Lee Wilkinson and documented in his paper “Exact and Approximate Area-proportional Circular Venn and Euler Diagrams”, available at http://www.cs.uic.edu/~wilkinson/Publications/venneuler.pdf  The corresponding computations are performed in Java, so you must have Java installed on your machine to run them.
The input can be either a single table with 0-1 variables or multiple tables with lists of items.  For details, click Add-Ins -> Venn Diagram -> Help after installing the add-in.
An example screenshot is below.
Update May 4, 2015:  The add-in now picks up the format of the frequency variable in the display.
Update December 20, 2018:  Fixes for Java on Mac and cN0[idx] error.
Comments
rossmiller
is there a way to format the data labels?  e.g. adding a comma to the number, changing .10 to 10%, etc, or hiding the labels so i can paste in my own?
russ_wolfinger
Basic editing is available by expanding the "Labels" outline box on the right hand side and making changes in the boxes within.  Please let us know if you need more advanced formatting.
russ_wolfinger
Ah sorry, that previous comment applies only to the labels for each Venn circle, not to the data counts inside the circles.   To format those counts I guess some functionality would need to be added.
nsadot
This is really a great tool. Wish it had a recall button
32103940
great addin! ditto on the Recall button
russ_wolfinger
Hi Venn Friends,
Just uploaded an update, featuring
- Automatic recall of specs in the dialog
- New dialog field that lets you specify a variable with a JMP format, and this format then gets applied to the counts
- New radio button in the display window lets you switch from counts to proportions, allows you to display percentages using the aforementioned formatter
- New checkbox "Density Points" provides a visual display of count density in the diagram
- Example data is now a part of the menu
Please give these a whirl and let me know if you have any problems or ideas for improvement!
MKostura
Just would like to ask about a functionality quesiton with the Venn Diagram Add-In.  It seems that it is not linked to changes that might occur in row states (eg Hide and Exclude).  If I hide and exclude row those still are being counted as part of the Venn Diagram.  Is there something that I may be overlooking in setting up the Venn Diagram or might this be bug?
russ_wolfinger
Good catch MKostura--just uploaded an update that now honors excluded rows.
MKostura
Thanks.  Nice first step.  But making this Venn Diagram addin completely and dynamically  interactive with row selection would greatly increase utility and uptake by the community.   Right now the fix allows for hidden/excluded rows to function but only as a refresh.  The user has to start over to get the updated diagram.  Connecting to the local data filter would help immensely.
This would be an excellent addition to the Graph Builder graph type menu.
irinastl
Can I build VENN diagram in JMP 13Pro?
Hi @irinastl,
Yes, this add-in works with JMP Pro, version 13 to build Venn diagrams.
Go to the top of this post and download the .jmpaddin file and open it in JMP Pro 13. You'll find a Venn Diagram menu at the bottom of your Add-Ins menu.
abh1
This is a great add-in. However, when I check the box for "Proportional Areas" I get the following error in a JMP Alert window: invalid subscript (must be number or list of numbers) in access or evaluation of 'cN0[idx]' , cN0[/*###*/idx] The Java version of the proportional diagram is produced, but it never gets into a JMP output window. I have tried this in both JMP Pro 13 and 14, and tried the SAS supplied java.exe as well as the java.com supplied version. All give the same error. Non-proportional diagrams work fine and look wonderful. Since the proportional diagrams are partially produced, I can resize and move all the circles to match that, but all that editing gets cumbersome pretty quickly. Is there a simple fix for this problem?
John_K
Does this only work on Win version of JMP ?
abh1
No, it works in JMP for Mac too. I think all JMP add-ins work anywhere. But this one also give an error in JMP for Mac when checking the box for proportional areas, although it is a different error message than in Windows.
John_K
Russ - thanks for all the recent help making this Add-In even better.
Now that the hard stuff is done... :)  I also echo MKostrua's comments above:
"But making this Venn Diagram addin completely and dynamically  interactive with row selection would greatly increase utility and uptake by the community.   Right now the fix allows for hidden/excluded rows to function but only as a refresh.  The user has to start over to get the updated diagram.  Connecting to the local data filter would help immensely.  This would be an excellent addition to the Graph Builder graph type menu."
AC_Repka
Hi Russ,
Love the venn diagram tool. I was wondering if an update that allows for display of shared object names (instead of just object counts) in the body of the graph would be possible?
Thanks
russ_wolfinger
Hi All,  Just in time for Santa's sleigh, attached is an update that should fix proportional area running Java on the Mac, as well as the cN0[idx] error.
@MKostura @John_K  there are some tricky issues in implementing interactivity from the JMP table back to the graph.  For example, exclusion/inclusion would trigger recalc of proportional areas, which can take 5-10 seconds.  Maybe not too bad for basic use cases but if you are making such changes frequently could get clumsy.   More difficult is how to display partial selection in the diagram itself.    For example, if only some of the rows of a Venn sector are selected in the table, how do we visually cue this?   My colleague Drew Foglia (now also a contributor) has been investigating a little and has the idea of water-fill shading from the bottom up in each sector.   Anyone seen any research along these lines?
@AC_Repka  Thanks, I'm not quite following.  You want to completely hide the object counts and instead show a list of states that define a particular sector inside each?   Wouldn't this get completely unmanageable for medium and larger data sets?  I may be completely missing the idea.  Do you have an example picture?
galactus3000
when doing proportional venn diagram with Single Table with 0-1 variables, I'm getting the error meansX[i] and i've traced it to around line 1240 of the VennDiagram.jsl code
at first i thought it was a typo and should have been meansX[idx], but meansX only his 8 elements, so upon show(i), I found that i was 256.
the error seems to occur, in my case, when idx=16, so i guess the if statement conditional is not met until then
// fill in any missing ones using average of circle centers
        cN0 = cN;
        show(two_to_nc);
        show(nc);
        show(i);
        for(idx=1, idx<=two_to_nc, idx++,
            if(cN0[idx]==0 & counts[idx]>0,
                cX[idx] += meansX[i];
                cY[idx] += meansY[i];
                cN[idx]++;
view log shows
meansX = [61.44375, 45.68125, 65.83125, 46.16875, 58.4375, 43.08125, 63.8, 62.90625];
meansY = [56.925, 41.56875, 47.0125, 50.83125, 56.51875, 36.85625, 50.9125, 52.375];
two_to_nc = 256;
nc = 8;
i = 256;
invalid subscript (must be number or list of numbers) in access or evaluation of 'meansX[i]' , meansX[/*###*/i]
galactus3000
the script does not crash (but resulting Venn diagram is ugly) if I replace meansX[i] with meansX[8] and same with meansY[i] to meansY[8]
galactus3000
guessing that meansX[i] should be meansX[ceiling(log(idx,2))] ?
russ_wolfinger
Just pushed a fix for this; apologies for the trouble.   Please download the updated attachment and reinstall the add-in.
Smn
Hi Russ and all,
Thanks a lot for this! Essential tool!
clarifications:
*Density points: can you give more methodological info on this (i.e. for reference in scientific articles)? BTW each time I run the same dataset the position of the density points changes.
*Format variable: how can this be used? Any "manual" to read?
Previous points/issues:
* Russ, I think @AC_Repka meant exactly that. For example it would be great for smaller size datasets. So, instead of displayed numbers or proportions, for each area, we would have the names - for ex., if I have "3" COLORS in a certain area of te Venn diagram, instead of displaying the number ("3"), we would choose to display their 3 names (for ex. "blue, red, green").
* @MKostura and @John_K Yes good points.
*Proportional areas: I just tried the new addin, and now it works (JMP 14).
Suggestions/ideas:
*Variables: the function "BY" would be very useful.
*Adding the "Keep dialog open" option would be very useful.
Thanks!
AC_Repka
Sorry I missed your message in the holiday scuffle. Yes, I think an option
for counts and/or list of object names would be very helpful. It may not be
great for large data sets, but I think it could be up to the user to decide
what is a reasonable way to display the data. Something along the lines of
this:
[image: image.png]
Thank you for your reply,
AC
