The RadViz add-in implements a multivariate plot based on normalized column values mapped to a radial axis. Good sample datasets would be Cereal.jmp or Iris.jmp.
Currently, the axes are ordered as specified in the launch dialog, and the mapping will vary based on the order selected. A useful addition would be to rank the columns in order to separate the columns that best separate the clusters.
