Fit Color Gradients
John_Sall
Data with extreme outliers (frequently seen in semiconductor test data) don't lead to a good color gradient when used in Graph Builder heat maps. The extreme range results in a gradient that puts the majority of the data in a small color range. This add-in creates a "Color Gradient" column property that gives a reasonable color scaling to represent the middle 95% (or other specified) of the data.
