One way to plot multivariate data is to use Chernoff faces. For each observation in your data table, a face is drawn such that each variable in your data set is represented by a feature in the face. This add-in uses JMP's R integration functionality to create Chernoff faces. An R install and the TeachingDemos R package are required to use this add-in.
