Browse apps to extend the software in the new JMP Marketplace
Capability animation: standard deviation impact
Completely interactive, this application allows users to explore the capability analysis of a column which has specification limits in its metadata. The goal is to see the impact of changing the standard deviation, or specification limit on capability analysis and, more specifically, on CpK and Cp. To use it, please run the add-in and choose a column which has some specifications limits coded. You can use the file Semiconductor Capability.jmp from the Sample Directory in JMP Help, and use whatever column that you want (VPM7 is a good illustration of the capability animation tool).7533_CapabilityAnim.JPG
