BookmarkSubscribe
Collection: One-Page Guides
A set of one-page guides are available individually from the JMP Academic Resources Center.  Links to the each of these guides along with videos (if available) are provided below.
Download the entire collection of one-page guides (with version 12 updates), combined for printing i... (you'll be asked to provide a bit of information before downloading).
Using JMP
Opening JMP and Getting Started
JMP Data Tables
Importing Data from Excel
Importing Text Files
JMP Tools
JMP Tables Menu
Saving JMP Results
Saving Publication Quality Graphics with JMP - Mac and Windows
Creating Formulas in JMP
Navigating JMP in Windows
Excel Add In I (Passing Data to JMP)
Excel Add In II (Profiling Excel Models in JMP)
Using the Add-In Builder
Graphical Displays and Summaries
Bar Charts and Frequency Distributions
Pareto Plots and Pie Charts
Mosaic Plot and Contingency Table
Histograms, Descriptive Stats and Stem and Leaf
Box Plots
Scatter Plots
Run Charts (Line Graphs)
Interactive Graphing with Graph Builder
Summarizing Data Using Tabulate
Mapping in Graph Builder
Probabilities and Distributions
Assessing Normality
Fitting Distributions
Finding Standardized Values (z-Scores)
Finding the Area Under a Normal Curve
Random Sampling and Random Data
Basic Inference - Proportions and Means
Hypothesis Test and CI for Proportions
Chi-Square Test for a Two-Way Table
One Sample t-test and CI
Two Sample t-Test and CIs
Paired t-Test and CI
One Way ANOVA
Two-Way (Factorial) ANOVA
Nonparametric Tests
Bootstrapping in JMP Pro
Sample Size and Power for Testing Means
Sample Size and Power for Testing Proportions
Correlation and Regression
Correlation
Nonparametric Correlations
Simple Linear Regression
Multiple Linear Regression
Simple Logistic Regression
Multiple Logistic Regression
Stepwise Regression
Time Series
ARIMA Modeling
Time Series Smoothing Models
Multivariate Methods
Clustering
Principal Components Analysis
Factor Analysis
Discriminant Analysis
Mixed models and Repeated Measures
Mixed Model Analysis
Repeated Measures using Mixed Models
Repeated Measures using MANOVA
Data Mining
Classification Trees (Partition)
Regression Trees (Partition)
Neural Networks
Creating a Validation Column (Holdout Sample)
Quality and Process
Variables Control Charts - XBar Charts
Variables Control Charts - I/MR Charts
Attribute Control Charts - P and NP Charts
Attribute Control Charts - C and U Charts
Capability Analysis
MSA Attribute Data
MSA Continuous Data - EMP Method
MSA Continuous Data - Gauge R&R
Reliability and Survival
Distribution Fitting (Life Distribution)
Accelerated Life Testing (Fit Life by X)
Designed Experiments
DOE Full Factorial Design
DOE Full Factorial Analysis
DOE Fractional Factorial Design
DOE Fractional Factorial Analysis
DOE Screening Experiment Analysis
DOE - Custom Designs
Using SAS from JMP
Connect to SAS OnDemand for Academics from JMP
Connect to Your School’s SAS Server from JMP
Connect to SAS on Your PC (Windows) from JMP
Setting SAS Integration Preferences
Using JMP to Generate SAS Programs
Entering and Running SAS Programs
The guides and videos are developed and maintained by the JMP Academic Team.  Contact mia.stephens , julian or volker.kraft for questions, suggestions, or additional information.
Do you have interesting course materials (data sets, scripts, activities or other teaching materials)?  Consider sharing with other educators by uploading to the JMP Academic Community. Thank you for your contributions!
Revised 10/13/2015.
The complete one page guide bundle is downloadable from the link at the top of this page.
Comments
Thanks for the update.  Very helpful!
